Desert Rat
- March 13, 2005
- Arizona
- Black 92 4x4 XLT
What do you guys think about these plans I have for my 92 4x4 Ex:
For the front I want to get the Canburg cut and bent beams and then either buy coil overs and fabricate my own shock mounts or just get 7 inch lift springs to "to accomadate for the 4inch lift of the bent beams and 2.5 J-Duff already on it" and longer shocks. Then I can just fabricate radius arms and crossmember and then buy the extended brake lines, dropped pitman arm and straps.
For rear I want to do a SOA or fab up some longer shackles because I don't want it level with the front too much. Then if I have to cut out holes in the rear "bed" of the Ex I will to fit the longer shocks. Also mind you that my truck already has a James Duff 2.5 stage 1 lift onit already with 31inch STS All-T's so I want to leave the front drop brackets for the extra lift.
I've been thinking about this for about a month now and just wanted to get some ideas from people who have Exploders too so I'm going in the right direction. Thanks
