t0ked
- November 28, 2011
- NYC
- 2006 Explorer V8 AWD
Yes another sparkplug thread, but I'm sure there are people still on the fence about tackling this themselves.
The patient is a 2006 Explorer. We bought it in 2011 with 80k miles. It's now at 96k mostly multiple short trips, prime candidate for carbon buildup. I used a bottle of seafoam just prior to the operation and tried to get as much highway miles as I could.
Even then, I had the worst of luck. Even following the TSB diligently, I only removed 3 plugs intact. The Lisle tool is a godsend. I used it on 5 broken plugs and the cutting thread on the extractor part still looks like it has life left.
So I started on a Friday evening by spraying a small amount of penetrant into each plug hole. I let it sit over night. I then soaked it up the residual penetrant and sprayed each hole with carb cleaner until it just covered the hex head as per TSB. I let it sit for a couple of hours. Then I backed out each plug 1/4 turn. Let it sit another couple of hours. I then started slowly backing out plug #8 with a little back and forth when the resistance seemed higher. The first plug broke, omen of things to come. This one broke right where the lower metal sheath ends, perfect for the Lisle tools. After using the tool once, it becomes second nature.
The next two came out intact. Then another broken plug, same as the first. This continued until the last two plugs. This time, the hex and the thread came out, but the porcelain core remained intact. I ended up taking a long screwdriver and cracked the porcelain. Luckily, on both plugs, it broke just above the lower sheath, perfect position for the Lisle tool.
So after 5 broken plugs, and 5+ hours of wrenching (a lot of panicking and cursing) I was able to remove all the plugs. I replaced them with new SP514 plugs coated in good quantity of nickel anti-seize on the lower metal shaft and capped off with MSD COPs (the ones originally on the truck were a mish-mash of motorcraft and 3 aftermarket ones, so I just decided to replace the whole lot).
There is no more sputtering and flashing wrench when I go WOT. Truck runs so smooth and feels the best it ever has. MPGs have increased tremendously. I was averaging 11.7mpg (yes, should have done this sooner) and now it has jumped to 17 which I'm extremely happy with.
The head design and the sparkplug design is probably the most idiotic I've ever come across. I've never had this much trouble changing sparkplugs before. This truck is the last FoMoCo purchase I will ever make.
