alohamonte
- October 4, 2007
- Glendale, AZ
- 1998 Explorer 4.0 4x4
I replaced the plugs and wires in August 2017 because I was getting misfires and a lean code/ CEL. Misfires stopp and CEL was reset and has not come back.
The misfire came back in December 2017, no CEL.
Since it had been over 100,000 miles since it was last done, I replaced the upper intake gaskets and while out, inspected the injectors. They all looked clean, no visible sign of build up. Gave them a quick soak, replaced the orings, and put everything back together. I also replaced the spark plugs again after seeing that #4 showed a bit dark, rest were normal.
After all of that, I could still feel the miss. So I connected the explorer to my phone via the Torq app to monitor it in real time. After driving for 60 miles, cylinders 1,2,3 showed 0 misfires. 4 and 6 each showed less than 10 misfires, and 5 recorded about 140 misfires.
The ignition coil still under warranty, so I am going to replace that just to rule it out. Aside from that, what could cause only the cylinders on the driver side to have misfires?
