BeemerBiker
- August 11, 2010
- San Antonio, Texas
- 1996 Explorer 4.0
I purchased the parking brake hardware kit from autozone. There were no instructions on how to assemble it and I failed to note the direction of the brake shoe adjusting screw. The brakes were adjusted when installed but are not grabbing. There is no pawl that causes the screw to expand with usage. I am thinking one or both are on backwards. Standard drum brakes the knurled knob faces to the front but that applies only to drum brakes with a pawl.
One screw I adjusted till the brake grabbed and then I backed off. The other screw would not turn and I had to remove the brake assembly, put the knob in a vice grip and turn the screw. It is as if the screw worked itself against the knob causing the shoes to contract. They need to expand with usage, not contract, or at least stay exactly where they are.
Possibly that screw was already binding when installed and never worked in the first place. The following picture is of the kit I bought from autozone. Does it make any difference which way the screw (5) faces?
