need help on transmission | Ford Explorer Forums
Brandon Chancey
hixson, tennessee
2002 ford explorer xlt
hey everyone new here this probably has been asked before but here goes. i have a 2002 ford explorer with the 5r55w transmission. the trans was fully rebuilt with new converter and the mercon v fluid once drove it kicked the o/d light flashing and code for shift soleniod problem. i replaced the soleniod pack and added a transmission cooler. now the fun part. once all was done and full of fluid i go to drive and i have nothing no reverse or forward gears. you can switch from reverse to drive and even give it gas and the transmission will not do anything. any advise would be great i have racked my brain and even pulled the transmission out had it tore back down to make sure everything was good and all looks new as it should.
@Brandon Chancey
Likely a problem electrically, maybe the harness connector to the transmission? Check operating pressure. If none, look at possible pump problem: pump bypass valve defective, dumping output to "tank" instead of developing operating pressure.
@JK080
imp
Thanks for joining, it's great to have you here
Tony
Maybe forgot the gasket under the solenoid block or maybe the manual valve got disconnected during the repair.
