J.Hurst02
- March 10, 2015
- Murfreesboro tn
- 01 Sport trac
i am building a rock crawler. its been my dream for a while. im putting a carburated v8 in my sport trac. i used the original starter wires to hook up to my new starter. when i put a battery in it everything worked except when i turn the key to the "start" position, i have no power to the starter wire. i have done some research on the pats system and found no answers. i really would like to keep from putting a push button start on it. (keep it stock looking)
being that i removed the motor and wiring harness on it and the ecu does the transponder module recieve a signal from the main ECU on the firewall which would prevent it to give power to the starter wire? is there a way to bypass the transponder module while keeping all this stock "turn key" style? or are there a couple wires i could just ground out or connect together to make this work correctly?
any help would be appreciated
