need pinout for grey transmission connecor 96 explorer | Ford Explorer Forums - Serious Explorations
PhantomFord
Petaluma, CA
1995 Eddie Bauer Limited
i need the pinout for the grey transmission connector. having to redo some off my older wiring from my manual swap. i did search, quite a lot before breaking down and making a request post.
The connector at top of the transmission spine from engine harness to transmission harness?
Is it round grey 8 pin?
its the square one that has the 02 and speed sensor harnesses along with what origionally went to the auto and the gear selector sensor.
I have a 98 and a 2000 wiring book in front of me, they do not have the same plug
Closest I can find online with a google search is this:
1999-ford-explorer-wiring-diagram-pdf-2004-transmission-2002-pcm-attachment-1-d-to-728x540.jpg
and this (5r55e should be basically the same as your 4r55e)
This is the harness I’m talking about. I basically need to know which pins to wire up reverse lights. I already have the neutral ones jumped.
reverse lights are black with pink on fords, single wire powers the bulbs when you put shifter into R
Found this:
index.php
index.php
index.php
Right here:
Reverse Light Wire
I found that info by searching this forum for "4r55e reverse light wire" of all things...sheesh searching for "4r55e wiring diagrams" I came up short
