Alright I want to make a few home-made LED light brackets myself but I am not sure of a few things. I have a special switch witch will handle up to 12 different leads. However it needs to be a two wire set-up. Meaning it has a spot to screw in for a + wire and - wire. How would I go about wiring this? I would like it in parallel, if possible. Would 18 gauge wire work?
Also, what kind of LEDs should I get. Here is a pic of the neon I have under the Driver's side dash now. It is bright and I would like the LEDs to be this bright, if possible. I figured 3-4 LEDs per bracket. I have cheepy 6" LED tubes under the seats right now from AutoZone ($15). Well.... you get what you pay for. Not bright at all. Looking for something better.
Lastly, how do you guys mount your lights on the passanger's side? There is a black box in the middle that breaks up the area pretty badly.
