Need some help | Ford Explorer Forums
Need some help
Data804
1994 Ford Explorer XLT
Im new on this site. Can someone show me how to take out the front headlights. I just cant seem to figure it out. If it is simple, my bad for the dumb question. Pictures would be helpful.
If you need to replace the bulb, reach around to the back of the headlight and unscrew the socket. You'll probably have to move the battery to get to the turn signal/park lights on the passenger side. If you need to replace the whole headlight assembly (cracked lens, etc) then get a phillips screwdriver and start taking stuff apart. Remove the plastic cover that connects the grill to the radiator frame. Remove the screws at the top of the headlight, and from there, I can't remember exactly what comes apart next, but it isn't that difficult. I recall that it's mostly screws and a few pieces that clip together. Just get in there and have at it.
Also check the performance lighting section, faqs
Thanks Man . Im about to buy the diamond 6pc headlight set. I tried to take it out by force but i cracked the chrome housing so ill just keep unscrewing crap till it falls out. LOL.
