Willard
- March 16, 2007
- Bloomington, Indiana
- 04 Ranger Edge
Ok, so for quite a while now the ex hasn't been running right. I have either a weak or dead cylinder. It has these two codes:
176 - O2 sensor fault, always lean
332 - Insufficient EGR Flow detected
Now the hard part. I have replaced plugs, wires, coil pack, O2 sensors, cleaned MAF, replaced EGR sensor, sollenoid, valve, and tube ( i broke the old one), and still no help. I should probably check out my wiring on the O2 sensors, that might possibly be the problem, but for now I'm assuming it's fine. The dead cylinder has compression, and there are no abnormal noises coming from the engine. It should be noted the dead cylinder is the second one on the passenger side, so it should have no effect to EGR. I'm stumped. I can't figure out what it could be. Any help anybody has would be appreciated.
