Negative Battery Cable | Ford Explorer Forums
morbid81
Keller,TX
1998 5.0L AWD Eddie Bauer
Hello All,
Trying to replace a negative battery cable on a v8 5.0 eddie bauer 98 explorer. But it looks as if its one solid cable with the postive and runs up underneath the car along the bottom of the engine to the starter and then splits off to the Oil pressure sensor on the side of the oil pan. I bought the negative cable from napa for the electronic message center but can't seem to find where just the negative cable is attached to the block itself and it's all wrapped in ripped tubing so this makes it even tougher. Any help would be much appreciated.
Here are some pics from another post the have a similar engine setup
http://www.explorerforum.com/forums/showpost.php?p=1717285&postcount=2
