New 4ch amp on stock HU | Ford Explorer Forums
Screech 96 EB
Peotone IL
96 Eddie Bauer
How would yoh hook a better 4ch amp with the stock hu and still keep the stock sub?
I wouldn't.
I'd get an aftermarket HU (which wouldn't need a 4ch amp for a moderate system), and a new sub/amp.
Basically there isn't a point adding to the stock system because you'll still have the stock limitations in the end. It's better to do it right once than do it in pieces and not be happy and spend more money.
But, if you want to replace the stock amp for the 4 corners all you'd need to do is go into the passenger interior panel in the cargo area and line-in the stock speaker wires into the new amp, and run new power and ground wires, and splice into the stock remote wire. Your stock system has seperate amps: 4 + 1.
How do you add and amp and some subs using the stock 6disc HU? Thanks
Basically get an amp that is capable of line-in, or a line-in converter. Then splice off of the rear speaker lines from the HU into the amp for the subs.
This question has been asked and discussed at length many times before, you'll probably be able to find all the info you need by looking through old threads.
