New AUX lights! need some advice. | Ford Explorer Forums
edflores3492
Deep South Texas
1998 Ford Explorer XLT
i recently purchased a rola roof rack and plan on putting some aux lighting up there ive already found the lights i want just need so advice as far as how to wire them. ive gone through the stickys up top and i get the idea just want to know if im gonna need a relay for each light or if i can just inline fuse it to switch and bypass using a relay. the lights im gonna use are a 32 inch 180W LED bar, 4 18W LED lights, and one 6 inch 36W led bar. im planning on having 4 switches. one for the 32 inch, 2 switches for the 18w lights, 2 lights per switch meaning 36 watts per switch, and one for the 6 inch light. im definitely going to have a inline fuse for each switch. the switches im looking at are off amazon and it says they are rated for 30A. does that mean i would only need to place relays on the ones that draw more than 30A? also im not quite sure on how many amps each light is actually pulling.. it only tells me the watts.. hopefully i explained myself well enough so yall can understand, ill give more info anything else is needed. Thanks in advance!
36 watts / 12 volts = 3 amperes.
180 watts / 12 volts = 15 amperes.
