I know of running a SOHC using a OHV computer, basically you ignore the valve cover mounted cam sensor
My buddy Brett did it in his 94 Sport using a 04 Ranger SOHC and 5 speed, it straight MOVES that truck, give my 5.0L BII a run for its $$$
But fitting a SOHC in a Gen I is tighter then the V8!!
He is pulling the engine again to make more room and get it 100% perfect, if you know Brett you know it will look and act factory or better
camburg and other So Cal desert racers are using the SOHC more and more, with OHV computers and 5 speeds or C4
enough so in fact Cullhane now produces a specific 4.0L V6 to C4 bellhousing, no more trying to lcoate a C5 or C3 pinto bellhousing for your C4 swap just need $400 LOL
My info says the cam sensor is used for start up only, some say the PCM uses it to adjust timing, James could probably tell us for sure what the effects are of ignoring it or hopefully removing its functions from the PCM with a tune
aside from that sensor they are just about identical through the years, the SOHC and OHV share the same transmissions, same physical dimensions (short block at least LOL), fuel systems, etc
95 to 97 auto trans is where the problem is, not SOHC to OHV
If you can use a stand alone transmission controller for your 97 auto then you can use a 5 speed computer for your V6 and use the 95 OHV LOL
stand alone controller = $$$$$$$$$ if even avail for the V6 trans
Now you are spending $$$ to make this work, why not spend $$$ towards a simple new SOHC or heck a V8 donor, same amount of work!
I am NOT sure you can run a OHV with a SOHC computer, I dont see why not??
my question would be WHY?? I know I know parts are free in this case
used SOHC from a 02-04 truck is about $400-500 these days, may be worth it
97 was first year and IMO a bad year for the SOHC, however I have seen some go 250K no issues LOL
