New headlights & clear corners | Ford Explorer Forums - Serious Explorations
The headlights are stock replacement but look a hell of a lot better than the yellowed originals. Sorry I don't have pics of the original headlights.
Clean and smooth! Nice touch! Were they easy to replace? When I did mine, I broke one of the little things that the pin snaps in to... I only did the corners up front. (I was told the thing that broke is called a gammit)
I notice your windshield is very clear and shiny... any secrets to keeping it that way?
Thank you for the comment. :)
The corners were a breeze. The headlights were a little more involved. The grill has to removed to replace them plus getting the old headlights out was a little tricky as well.
As for the windshield here is the trick.
Get a small bucket of water and a sponge and soak the sponge with water. You will also need a can of Bon-Ami
Wet down the windshield. Next sprinkle Bon-Ami on the windshield and then use the sponge to scrub the windshield. Just be careful as not to get the A-pillars or the roof. The Bon-Ami removes all the road grime that window cleaners can't remove.
After cleaning the windshield dry it off and then give it two rounds of Rain-X.
You can do the same thing to the door and rear glass as well.
One word of caution. DO NOT USE COMET. Comet is to abrasive & will scratch the glass.
That is what you call a showroom finish/shine! Thank you for the advice, I will try it...
Amen- someone else that actually uses Bon Ami! Been using it for years to get rid of the grime from my windshield... Also used it to clean the leather seats in a couple of my SHO's... Works awesome! :thumbsup:
