New ? How to turn Fog Lights on??? | Ford Explorer Forums
navarretg
Central VA
'08 EB
I finally took apart the headlight assembly and changed my headlights, but I noticed that my fog lights did not turn on?? I turned the switch all the way to the right and the fogs stay off? I read the manual that you have to pull the switch back towards you, I tried that but no luck. Can someone please help. Thank you!
ok i checked the owners manual online and it says do as you have said. But they only work if your high beams are off. If that doesn't work check your fuses. and if that doesn't work hopefully you got a warranty
