WilliamWallaceGS
- August 22, 2012
- Hampton Roads, VA
- 1994 Ford Ranger
Hello all,
Just wrapped up my rebuild of my 1994 Ranger 4.0. Sent the block out to a machine shop and had them go over it, new bearings, rings, seals, etc. Threw in a Melling High Flow oil pump, Comp Cams 410 Cam with 95tm heads, JBA headers, etc. etc. All new sealed power lifters, rocker arms, and 5.555" push rods from Smith Brothers.
Before I tore the engine apart, I didn't have any lifter tick, but I bit the bullet and ordered all new lifters because I was doing a complete rebuild. I soaked them in oil for several days before installation.
I've only driven the truck a few miles, and I've had it idling for a total of maybe 20 minutes to check for leaks and whatnot. I have a lifter tick that's pretty noticeable standing outside, but inside it's not that bad.
So the question is, how long does it take for lifter noise to go away? I definitely don't want to rip the thing apart again to replace NEW lifters. I didn't measure for pushrod length, but went with what was recommended on a few forums I read around on (including this one), so I'm pretty sure my pushrods are the correct length.
I just got back from my first drive, and I'm letting everything cool down so I can double check my header bolts and spark plugs and all to make sure that may not be making the noise. But if it's not, how long does it typically take for brand new lifters to finally fill and become quiet?
