- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
It's good that the hatch will close to where it needs to go. If the hinges are tight enough, they won't need to be replaced. If either one is a little loose, the hinge joint, then it will wear out the strikers faster than normal.
The hatch is really heavy, if you need to loosen any of those bolts, you will likely need help to handle the hatch while moving or adjusting the parts.
