swetrid
- September 30, 2010
- Reading Pa
- 1999 Eddie Bauer
TSB
12-2-7 TIN ROOF NOISE - FRONT ROOF AREA DURING RAIN - BUILT ON OR BEFORE 11/5/2011
Publication Date: February 10, 2012
FORD: 2011-2012 Explorer
ISSUE:
Some 2011-2012 Explorer vehicles built on or before 11/5/2011 may exhibit a noise similar to rain hitting a tin roof. The noise is coming from the front passenger compartment.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Remove both sun visor screw covers and allow both visors to hang down.
Install shop towels or equivalent directly beneath the foam insertion points to protect the interior of the vehicle.
Using Fusor® 121 flexible foam repair kit.
Install a mixing tip onto the expandable foam cartridge.
Attach a 15.24 cm (6") piece of 0.635 cm (1/4") ID x 0.952 cm (3/8") OD (max) rubber tubing to the mixing tip.
Secure the rubber tubing to the mixing tip with a cable tie, tape or clamp. (Figure 1)
Figure 1 - Article 12-2-7
NOTE: ONCE THE PRODUCT STARTS MIXING IN THE MIXING TIP YOU NEED TO WORK VERY QUICKLY.
Starting on the left side of the vehicle.
Locate the square opening on the rearward side of the sun visor mounting cup. (Figure 2)
Figure 2 - Article 12-2-7
Insert rubber tubing all the way into this opening while curving the tubing toward the center of the vehicle. (Figures 3 and 4)
Figure 3 - Article 12-2-7
Figure 4 - Article 12-2-7
Pull the handle enough to fill the mixing tube. Once full, pull the handle an additional three (3) times.
Withdraw the hose 25 mm (1"), then pull the handle two (2) times. Repeat this four (4) more times, withdrawing the hose 25 mm (1") each time.
Repeat on the right side of vehicle using new mixing tube and rubber tubing.
Allow the product to fully cure following manufacturers recommendations.
After curing, remove any excess foam that may be in the sun visor mounting cup.
Remove protection from vehicle interior.
Install sun visor assemblies and install the two (2) sun visor screws.
Install the sun visor screw covers.
This procedure will improve, but may not eliminate the noise entirely.
Locally Obtained Supplies
Part Number Description
121 Fusor® 121 flexible foam repair kit
N/A Cable Tie
N/A Tape
N/A Clamp
N/A Rubber Hose 0.635 cm (1/4") ID x 0.952 cm (3/8") OD"
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
120207A 2011-2012 Explorer: Install Foam Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.5 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
7850202 68
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2012 Ford Motor Company
ISSUE:
ACTION:
SERVICE PROCEDURE
N/A Cable Tie
N/A Tape
N/A Clamp
WARRANTY STATUS:
DEALER CODING
7850202 68
