fpoya
- May 18, 2009
- portland or
- 96 xlt
thanks in advance, my speedo on my 96 explorer dosnt work i took out the vss and attached it to my drill turned the key and hit the trigger and the gage worked my drill will hit 65 mph then i reinstalled the censor and the speedo dosnt work i droped the drive line removed the flange and seal so i could see the gear on the output shaft of the transfer case. i dosnt look chewed up i can rotate the gear on the shaft
questions; is this right and if so how come my speedo dosnt work and if not how do you r+r the gear (please say through the back of the case)
