abacus6
- September 26, 2005
- fredericksburg, va
- 2000 sport
tried this in the 1995-2001 forum w/ no response, thought i'd try here...
Bought a 2000 sport 4wd this summer, about 62k but in good shape ( cosmetics and engine). One issue i've come upon. I feel some sort of rubbing/grinding from the front passenger side while driving...quite pronounced while braking. Recently noticed a wobble in low speed (10-20 mph). Obviously an alignment check is needed, but I feel it's just a symptom or result of a bigger issue. Took it in for brakes to be checked and the brake dude ( who by the way, sed brakes were at 70% whatever that means...didn't replace anything) spazzed on me, going on about the front passenger wheel bearing being out and proceeded to demonstrate that neither wheels should pass inspection by lifting each wheel vertically with a pry bar about 1/2 an inch. I thanked him and left him to his mutterings...
i did a search here on the wheel bearing issue and found a few threads ( one seemed to match my noise complaint ) but there is NO way i can re-pack, or whatever, anything on my own.
the crux : does this sound like a wheel bearing issue? what on earth does that mean? i thought a bearing was a small metallic ball......if so, steps to remedy? and, IS it weird that both front wheels ( with the explorer raised ) can move vertically like that...independent of the suspension, obviously...just the wheel moving not the suspension travelling...if so , remedy?
sorry so long...thanks in advance!
btw, i purchased a warranty when i got the explorer, just wanted to get some wisdom prior to going through them...gotta use their recommended shop and such, don't wanna get screwed b/c they don't want to do any work...
