No Brake Lights | Ford Explorer Forums
No Brake Lights
ranger02
Bellevue, KY
'02 Edge
I have absolutely no brake lights. Turn signals and hazards are fine. Replced the BOO switch with no result... What else could it be?
Check the fuse?
You can check the new BOO switch by jumpering the wires, look at the lights.
If no go then its time to get the multimeter out and check for continuity between the BOO switch and the bulb sockets/ rear light wiring.
Could be many things, a short, a power feed, a stock plug unplugged, etc.
two bad bulds?
You have turn signals? parking lamps?
bad connection at the connector??????
