mr cribb
US Army Retired
- December 16, 2010
- Naylor, MO
- 98 Z71, 89 stepside
SOLVED: no CEL / no start, cranks fine
I have been working on my 92. My wrecked parts truck donated all the power accessories, as mine was originally a manual everything truck.
Part of my engine harness was burned so I started swapping harnesses, 2 days later, I have a complete 1991 power everything harness.
I will have you know, that the main connecting plugs DO NOT match on a 4/91 and 11/91 build date trucks. I am running the 4/91 harness now.
THE ISSUE:
No CEL, no start, cranks all you want. I do NOT hear fuel pump cycle when turning on the key.
WHAT I HAVE CHECKED:
Inertia switch - it is NOT tripped
power to distribution box - all maxi fuses have power.
relays (by distribution box) are all swapped with known working versions.
ignition control module - is swapped for a known working version.
The PCM is from my 92 model truck.
All I have is a test light, no multi meter.
I am almost certain I secured all the harness grounding points.
I can tell you that the wrecked truck did the exact same thing, before I stripped it.
I do know that no CEL, means PCM isn't communicating to fuel pump, but what do I check?
I have a few days before my wife goes out of town, and I am without a ride.
THE ISSUE:
