Bailey57
- May 22, 2014
- 93 Aerostar
This is a 93 Aerostar with 176K. It went for smog today and even though it passed the sniffer test by a hair, he failed me because he said first that I had a code indicating incorrect timing and then because my check light did not come on. I checked the fuse panel and cannot find a fuse, I then turned the key on to verify no check light before starting. I assume it is the bulb. If I am correct will someone tell me that is the only possibility please!
