cleudard01
- May 18, 2008
- White Sulphur Springs, W.V.
- 97 & 97.5 expl.spt
Hi guys, back at the 'ol 97 sohc. Raining today & got in it & no crank. Checked battery & cables, ok. Checked inertia switch, ok. Jumped solenoid w/key on & starts & runs. Loosened tranny position switch & rotated it while in crank position, still nothing, also tried starting in every shifter position.
Noticed the small red wire @ the solenoid wasn't doing anything in the start position. Should go to power or ground, shouldn't it? Everything seems to be acting ok in the start position, fuel pump runs, electrical, lights, radio & all flash off in the crank position, just as it should. Starter relay seems to click too. I did jump pins 30 & 87 just for fun, & still nothing. Not sure I had the right relay. Is it the 1st or 2nd relay from the front in the row beside the battery? I think it was the 2nd. I guess I might need a wiring diagram or PCM inputs & outputs & wire colors, I don't know......PLEASEEEEE HELP!
