IAmTodd
4x Explorer Veteran
- April 8, 2002
- Johnstown, PA
- 2015 Jeep
I'm looking into buying a very cheap 97 XLT SOHC with 135k on it. I have yet to look at it but it sounds to be in good shape for the year/miles. The only downside is first gear seems to have gone on holiday.
According to the owner first gear (and probably 1st+OD for second) is not engaging. Reverse still works and you can start out in second and after moving shift into drive and it will drive fine until it needs to select first again when coming to a stop.
I've done a good bit of searching and from my research it sounds like the reverse/first band and clutch it still ok since reverse functions. It's looking to be more of a valve body issue. Best case scenario would be a blown out seal but I'm hoping someone can shed some light on possible causes. There's quite a few cases documented on the forum but no real solutions posted that I've found.
