ttbit
- June 24, 2004
- Maryville,TN
- '01 ST 5.0 sold
'07 ST8
Well, I accidentally messed up the front seal surface on my transmission pump so I had to replace the darn pump. I bought one used. While I had everything drained, I decided to do a Baumann shift kit. Finally got everything back together. After 12 quarts of tranny fluid, still no go. At one point, I revved the engine a little in drive and it went into some forward gear pretty firmly. Hasn't done anything since and never did grab reverse.
Ok...so...so many things I could have messed up, I suppose. Any suggestions on things to check first?
I checked connections for the range sensor and transmission main connector. Checked fuses (did a quick visual).
Seems like when I first put it in drive to just run it through the gears, I heard a pretty loud click. Haven't heard it again since. Almost a snap or loud relay or something strange like that. Like you would hear your A/C compressor do when it engages.
It might be making some strange noises in park now too. Hard to tell. Humidity is at 130% out there and I couldn't get the exhaust to leave the garage, so I had to call it quits for the night.
I have a datalogger too, if there is something I can datalog to check for. No error codes out of the computer yet either.
This is a 1996 Explorer 5.0/4r70w that I put in my Sport Trac. It did run fine before I had to replace the front pump as it was leaking.
I dunno. :scratch:
I dunno. :scratch:
