no rear brake lights | Ford Explorer Forums
showme71
JEFFERSON CITY, MO
'01 Ford Explorer Sport
I have a 2001 explorer sport. I have replaced the brake switch twice in the last few months and i have still no brake lights, but the third light is still working. Does any1 have any idea what is causing my problem ? Please help !!!!
likely cause is your MFS switch
Have you checked the fuses? I "think" the tail lights are fused separately from the 3rd brake light. I remember having a similar issue with my 01 when I was working on my trailer lights, and my problem turned out to be blown fuses.
all fuses are good, none blown
It could also be your tailight sockets are bad, although it would be unusual for them to go out at the same time. I've had to replace both of mine but they went bad one at a time.
Maybe obtain a wiring diagram and test the continuity/resistance of the wires to make sure they're still conducting properly? There could be a disconnect, corrosion or short somewhere?
as I was saying, likely cause of your PARTICULAR problem IS the MFS switch.
