ayyno
- May 12, 2009
- Blackwood, New Jersey
- '92 Eddie Bauer
Excuse me if this is a little vague or confusing, it's 3 am and I've been desperately searching to no avail, so I'm going to post it here.
I have a 1992 Eddie, and recently while driving it kind of half died for about half a second and was fine again, I was low on gas, but not empty(I've been lower) so I assumed I was running out of gas and as I pulled in the station it died and rolled it. Laughing about it thinking I ran out of gas we pushed it to the pump I put some gas in and went to start it...nothing.
I had no fuel pump sound, no check engine light. I assumed the fuel pump was bad...but I was able to jump the relay and it whines...so the fuel pump is good(thank god)
Now then I realized the CEL didn't come on when I turned the key at first...so I then figured it was the EEC relay...replaced that with a part from NAPA, didn't change anything. Using the paperclip method I was able to pull no trouble codes.
I'm worried that the EEC or "ECM" relay from NAPA doesn't have the same wiring or setup(can't think of the right terminology right now) as the relay I have, does anyone have a diagram or anything?
Any help is appreciated, if any more information is needed, obviously I'll give it to you. I just need to get this truck running again. I'm really hoping it's not a bad ECU.
