You could be experiencing more noise depending on the year model of your Explorer and the type of filter. If you just have the drop in replacement filter, it may be slighly more noisy but probably not much. If you drilled holes in your airbox, you will have more noise, as well as more airflow and an increase in performance you can probably feel. You may not have the airbox cover properly secured back on.
If you have replaced the stock system with a conical filter, you probably will have more noise due to the increase in air flow.
In either situation, you need to reset the computer so it will recognize the modification.
Ira
91 XLT 4x4
