Not enough bass in XLT with 8 speaker stereo
rsteen82
Edwards AFB ca
2011 XLT
Anyone add a sub/amp to their stock 8 speaker system? There isn't enough bass for my taste, so I want to add some, but without having it look or interact any differently then stock (just more bass!) :salute:
BradR
Novi, MI
'99 EX 4.0 OHV
You could add an inline converter and tap that to a speaker and run your amp/sub combo...
With an inline converter it has speaker wire that you splice into another speaker and that would give you RCA terminals and then you plug your amp into those for signal and run all your other power/remote/ground as normal.
W
w1kedz
I purchased a processor (maxxsonics mx-1), and have a kicker 10" solobaric square sub to drop in, I just haven't had a free weekend to do the install yet. I'm using a small custom enclosure that I'll be able to put between the 3rd and 2nd rows (under the false floor, when the third row is stowed), or moved to the very back when the third row is up.
I may try to get this banged out next weekend pending no more "surprises".. I'll be sure to take lots of pics.
MikeCallery
'11 XLT Tri-Coat
I have not researched it fully, but now from schematics that the Limited has a sub-woofer in the passenger side back panel in the cargo bay area. The Limited also uses the exact same amp as the XLT, so, by deduction, you could consider adding the factory sub-woofer and likely the wiring is in place for it.
shmty25
Has anyone taken off that cubby panely on the XLT yet to see what the amp and existing wiring look like? Just wondering if it is indeed possible to just easily drop a sub into that cubby area.
MikeCallery
'11 XLT Tri-Coat
Yup, last weeked I had it all out removing the 3rd row seat.
The amp is on the PS, pretty small and simply has two molex connectors entering, one at the top, one at the bottom. If you are looking at taping one of the wires, since there is a speaker back there in the same area and the wires are color coded, I'm sure you can grab that wire for a tap.
1995E
Maryland
95 + 11 Ex both XLT
There was a post where someone removed the whole panel. I think it included pictures. It was a while ago though.
MikeCallery
'11 XLT Tri-Coat
There are pictures but I don't think they explained with pictures how to remove the panel, simply a pic of the end result. I just did the same thing, removed my 3rd row by pulling those two panels so if someone wants to do that, just get back to me and I'll explain here. It is not that difficult, actually not as hard as I thought it would be.
GWA1
New Castle, DE
2011 Explorer Limited AWD
I'v got a limited with the Sony. The sub-woofer is sub-standard. The sound system is great except for the base. The base is better in my wife's RAV4 although overall quality isn't.
Remeny
Sugar Land, Texas
2011 Ford Explorer XLT
I'm interested in learning how to remove the 3rd row.
M Bass knob? Modified 2011- 2019 Explorers - Tuning & Mods 1
R Steeda springs (555 8202) vs Sport explorer springs (DB5Z-5310-K) in my XLT with B6 install Modified 2011- 2019 Explorers - Tuning & Mods 5
realscot2 anyone connect this to a stock XLT Modified 2011- 2019 Explorers - Tuning & Mods 7
realscot2 Swap out 2018 XLT grille for a 2015 sport Modified 2011- 2019 Explorers - Tuning & Mods 2
B Black "XLT" Letters for liftgate? Modified 2011- 2019 Explorers - Tuning & Mods 3
G Installation of Power running boards on my ford explorer 2015 XLT Modified 2011- 2019 Explorers - Tuning & Mods 4
E Need help in 2019 xlt audio Modified 2011- 2019 Explorers - Tuning & Mods 0
A 2011 XLT HD radio upgrade Modified 2011- 2019 Explorers - Tuning & Mods 1
E 2019 Explorer XLT Audio Modified 2011- 2019 Explorers - Tuning & Mods 1
J Upgrades for 2018 Explorer XLT Base? Modified 2011- 2019 Explorers - Tuning & Mods 1
G 2015 ford explorer XLT Door Unlock Wire Modified 2011- 2019 Explorers - Tuning & Mods 2
realscot2 stock xlt 4x4 suspension/steering modification Modified 2011- 2019 Explorers - Tuning & Mods 9
R Sct x4 in a 13’ xlt? Modified 2011- 2019 Explorers - Tuning & Mods 1
D Havis console install 2017 XLT Modified 2011- 2019 Explorers - Tuning & Mods 2
E 2012 Explorer XLT driver door speaker replacement. Modified 2011- 2019 Explorers - Tuning & Mods 4
L How to install a factory tow package on a 2016 XLT Modified 2011- 2019 Explorers - Tuning & Mods 20
P Upgrade XLT Cloth Seats to Limited Heated Leather Seats Modified 2011- 2019 Explorers - Tuning & Mods 1
M 2013 xlt mods!! Modified 2011- 2019 Explorers - Tuning & Mods 1
S Updating the 14' XLT Modified 2011- 2019 Explorers - Tuning & Mods 2
L Stock 2013 XLT "Mods" Modified 2011- 2019 Explorers - Tuning & Mods 8
B 2011 Lifted XLT Project Modified 2011- 2019 Explorers - Tuning & Mods 42
B New 15 XLT Owner- Is Tuning Worth It? Modified 2011- 2019 Explorers - Tuning & Mods 15
Q Front Tweeter replacement? 2011 XLT w/202A Modified 2011- 2019 Explorers - Tuning & Mods 8
cwescapexlt4x4 So far my 2013 XLT Modified 2011- 2019 Explorers - Tuning & Mods 27
B 2015 XLT to Sport appearance project Modified 2011- 2019 Explorers - Tuning & Mods 33
Y Installing OEM Subwoofer 2011 XLT Modified 2011- 2019 Explorers - Tuning & Mods 2
W Sport wheels/grill on XLT? Modified 2011- 2019 Explorers - Tuning & Mods 21
S 2014 Ford Explorer XLT Premium Sound system having trouble with noise from amp. Modified 2011- 2019 Explorers - Tuning & Mods 3
K 2011 Explorer XLT (My Way) Modified 2011- 2019 Explorers - Tuning & Mods 11
T wiring diagram for 2014 Explorer XLT brake and rear turn lights Modified 2011- 2019 Explorers - Tuning & Mods 1
M Debadged and Grayed Out XLT 2012 Modified 2011- 2019 Explorers - Tuning & Mods 41
M My Explorer XLT aka The Beast Modified 2011- 2019 Explorers - Tuning & Mods 2
S Our 2014 XLT - Progress thread Modified 2011- 2019 Explorers - Tuning & Mods 6
M Wheels-2012 xlt Modified 2011- 2019 Explorers - Tuning & Mods 3
H 2013 xlt 202A 9 speaker premium audio amplifier? Modified 2011- 2019 Explorers - Tuning & Mods 5
S 2013 XLT: "Upgrade" chrome front grille to body color Modified 2011- 2019 Explorers - Tuning & Mods 3
M Wheel Brand on XLT or Limited Modified 2011- 2019 Explorers - Tuning & Mods 10
B New 2013 XLT: Will painting my grille void any warranty? Modified 2011- 2019 Explorers - Tuning & Mods 7
J 2011 Explorer XLT Modified 2011- 2019 Explorers - Tuning & Mods 3
T My XLT Mods Modified 2011- 2019 Explorers - Tuning & Mods 6
T Inflatable seatbelts on base model (or XLT/Limited/Sport w/o the belt option) Modified 2011- 2019 Explorers - Tuning & Mods 14
S 2011 Explorer XLT side view mirror convex inserts unsafe at night! Options? Modified 2011- 2019 Explorers - Tuning & Mods 4
R Convert XLT from regular to tow package Modified 2011- 2019 Explorers - Tuning & Mods 1
J 2012 XLT with some upgrades...:) Modified 2011- 2019 Explorers - Tuning & Mods 5
jcerrion Max tire size - XLT Modified 2011- 2019 Explorers - Tuning & Mods 26
jcerrion XLT Wheel Change Modified 2011- 2019 Explorers - Tuning & Mods 1
M Painting XLT Grille Modified 2011- 2019 Explorers - Tuning & Mods 22
S HD Radio to XLT with 202A Rapid Spec Modified 2011- 2019 Explorers - Tuning & Mods 2
R Adding DVD and ambient lighting to XLT Modified 2011- 2019 Explorers - Tuning & Mods 18
Similar threads
