MustangP51
- January 16, 2005
- Connecticut
- 2009 Limited V8
For the last year my transmission (4r70w) has been shifting hard every now and then. It will have a few good shifts, then usually when it downshifts from 4th into 3rd while under a load, and at a low RPM around (1500) the will be a very hard shift. I had it looked at my friends shop, couldn't find a problem, and the fluid was changed, flushed and replaced with Mobil 1 ATF. That was about 9 months ago.
Now yesterday while driving I pushed the Overdrive button on the end of the shifter and the O/D Light did not come on in the cluster and would not turn off the overdrive. Pulled over shut the engine off, restarted the engine O/D indicator light still refused to turn on, and the overdrive refused to turn off. Got the thing home. Let it sit over night, and in the morning it was fine. The overdrive light was working and the overdrive could be turned on and off.
I am at a TOTAL loss for what could be the problem with the transmission. I can break down any other component of a vehicle in my sleep, but automatic transmissions are like alien technology to me.
What should I do at this point? She is not moving until this is sorted out.
