zhanx how did you fit a 33 under your X? i thought it was hard to fit a 31 let alone a 33
___Hmmm... just to throw something in here, how hard would it be to put in a pop-out sunroof on an Ex? Would it just require cutting out the sunroof panel from another car, cutting out the roof of the Ex, welding it in and touching up the trim pieces, or would I have to reinforce the sheet metal around the sunroof as well?
I haven't even started lifting and it's already not high enough...![]()
_________Heat could cause the roof to warp or loose it's rigidity, correct?
I found a place that'll sell me a BII carrier for $25 bucks, so I'm hoping I'll have time to get out there and pick it up along with a full set of wheels... I just read another thread on a lift, and I'm considering going higher than my originally intended 2"... I haven't even started lifting and it's already not high enough...
Fil
Ok, I was going to go to the junkers tommorow, but the South-West coast of BC (Read: Vancouver) is on an Earthquake Alert for the time being... the scientists say that if an earthquake is to happen, it's most likely to happen sometime in the next week. Apparently it's supposed to be about 75 km off the coast of Vancouver Island and could be about 9.0 on the Richter scale...
So, having said that, I'm not driving across the bridges for the next week and a bit, which leaves out going to the wreckers... I think until then I'm just going to replace my muffler and put in new plugs and wires... I also need to replace my fuel filter (when it stops raining) and do an oil change...
Fil
HAHAHAHA WHAT!!! Im in surrey and I have never heard that yet! Maybe ill check out the news! Dont be scared of the bridge, thats no way to live! You know you might hurt yourself wheelin tooI hear yeah on the rain tho! Oh yeah I got a tire carrier here too from my BII.... Now it had a 35x12.5x15 on there, the only problem was the rear hatch is made of fiberglass, so not strong enuff, so I took it off. I may get rid of it tho if you want it
