DasFrem
Elite Poseur
- February 21, 2000
- Portland, OR
- 2 '97 sports
So I've been beating myself up about this problem for a couple of weeks and have finally decided to ask for help...(97 4.0 V6 ohv)
A few weeks back, I was about 100 miles from home and the oil gauge is dropping to nothing, then back up, and sometimes just flicking back and forth. I know its a dummy gauge and think that I might just be a little low on oil. I check the dipstick and it looks fine. Back on the road and it's fluctuating even more now and the dip stick still looks fine, so I add half a quart just for the hell of it. Seems fine for a couple of miles until the truck starts running really rough...I pull over and its smoking like hell from the oil leaking out of the back of the motor on to my clutch. So I know I'm leaking oil out of the rear main seal, but I'm suspecting an issue with the oil pump because when I start it up, it won't have oil pressure at all until I really get on the gas. But it still ran like s#it for the last 40 miles of the trip (I was on an early workday duck hunt and had to get back in time for work, otherwise I would had it towed). Now when I dropped the pan, there was very little oil left, maybe 1.5-2 quarts.
OK, here are my main questions....
-What does a bad oil pump behave like?
-Should I just replace the rear main seal and hope for the best with the oil pump?
-Am I missing anything?
So far the trans is out along with the clutch and pressure plate so I know for sure it's leaking from the rear seal...I've also got the oil pan off and there's some fine metal shavings at the bottom of the pan, but nothing blocking the screen on the oil pump.
Thanks in advance to anybody who can shed some light on this issue.
