Russell Bennett
- September 26, 2017
- Abu Dhabi, UAE
- 2012, Explorer & Limited
Good Day Folks
My 2012 Explorer Limited 3.5L V6 has started to stall in the last 7 days when idling. It also nearly stalls under heavy braking and complete stop. When it stalls 'Low Oil Pressure' warning message appears.
The oil level and condition is fine.
I was going to start by eliminating possible causes, first being replacing 'Oil Pressure sensor'.
I located this last night tucked above the oil filter and A/C Compressor.
Could not see a way to change without removing A/C compressor, seems bit extreme for such a usually easy job.
Any advise from you good folk who have changed the Oil Pressure Sensor in the Past on a 2012 Explorer.
Thank you
Regards
Russ
Thank you
Regards
Russ
