dmr1203
- July 17, 2004
- Atlanta
- 1996 eddie bauer
I installed a radiator and everything went fine. I developed a small leak on the upper transmission cooling line at the bolt that goes to the radiator. I decided to take the bolt out and put permatex on it, and when I started to unscrew it, I twisted the cooling line. I have to get this thing out or it will continue to leak. I did however out permatex on the transmision cooling line connector, so when I try to seperate the two connections, the transmission lines kinks further. Any ideas?
Also, I tried to largest wrench in my set 7/8, and it is too small........besides a crescent wrench, do they make one larger?
