Old member first time posting. My SAS. | Page 3 | Ford Explorer Forums
Nice fab work as usual man. Glad to see you're still around.
Thanks and I'm still around. I don't plan on getting rid of the truck anytime soon since it does everything I want it to and my wife still loves it.
Are you still running the welded on high steer arm? Have you had any issues with it?
Still running it and I haven't had any issues so far even with 5 years of wheeling with it.
Great build love the rear bumper and tire carrier...
Cheers...
I have a 2001 sport trac 2wd and I was wanting to convert it to 4wd, is there any size front axle I could put in it? What size would fit or could I get one off a junk yard truck?
Cheers...
I have a 2001 sport trac and wanting to convert it to 2wd to 4wd is there a straight axle size I could use or maybe get one off an older explorer with a straight axle on it?
I used a Dana 30 off a Jeep Cherokee for mine. It is 1.5 inches wider than the factory width of the Explorer if I remember correctly and I moved it 1.5 inches forward so that the 33s I planned to run would have the same clearance from the fender as the 31s I was running had.
could you post a picture of the steering box installed? thanks.
I don't have any of the box installed but I do have some from when I had to modify the bracket for the V8 swap.
The bracket in the old position.
The hole in the frame.
The piece I removed.
Welded in place.
I've wanted to build a roof rack with a mount for a LED light bar for a while now. While talking to my nephew a couple weeks ago he told me that he had a bunch of 1 inch square tube that I can have plus a 40 inch light bar so I decided now is the time to build one.
I searched online to get an idea of what I wanted to build and found that most people using square tubing just did squared off corners which I didn't like. Instead I cut 2 inch pieces at 22.5 degrees to give it a 45 degrees corner. I also made it 4 inches tall because I didn't like the way 6 or even 5 inch tall racks look.
I started out by measuring the roof and decided to make the rack 83 inches long and 42 inches wide. Then I drew it out on my garage floor so that I could lay the tubing out to weld it.
Once I had the frame welded I cut the cross braces and welded those on.
After that I removed the old rails from the truck and cut plates to roof to seal the holes from the old inserts. I welded those on and painted the roof. I taped off the tops so that I had clean metal to weld to.
I then set the base on the roof, spaced it up from the roof and then cut down bars to weld to the plates.
After that I welded the top frame together and cut the tube to connect the top and bottom.
Then I made the base for the light bar and painted the rack.
I test fitted it with the light mounted and decided I didn't like how high the light sat with the way I had the mounts. So I cut them off and lowered them. I also added aluminum sheet under the light to keep it from glaring off the window.
I was ready to weld the rack to the roof when my brother convinced me to make it a bolt-on so that if I ever need to remove it I can. So I cut out some tabs to weld to the roof plates and then painted them.
Well that suck's none of the pictures show up for me...
How about today? They are all on my photobucket and I heard they went down yesterday.
pics show up for me and they are :eek::eek:!! I wanted a "wow" emoji, that one says eek...what I'm trying to say is the rack, rear bumper, and fab work are sick!!
Did your Exploder not have a rack and pinion steering system? I have a rack and pinion on my 99 Mountaineer and looking to SAS, but I need to know how to make the steering work.
Yes, mine had rack and pinion. I used a steering box from a first gen Explorer when I did mine but I don't like the ratio. I heard the F150 is better but a friend gave me the Explorer one for free so that's what I used. My steering wheel take four turns lock to lock.
The Pictures of Steering Box are still not showing up. I am now seriously thinking of doing the same SAS as you did here. Love the look of your Explorer.
Sorry about the pictures. They are on my Photobucket account so no one can see them anymore. I'll see if I can find the originals and then upload them somewhere else.
Just wondering if you figured out the pictures.
If youre using firefox and a few extensions they will show up, at least about 80% of them.
