south59
- June 30, 2004
- Houston TX
Hey guys
I just checked up on my tranny fluid in my 95(4r55e) and realized that my mechanic overfilled this thing WAY too much. The fluid level is at least 2 inches over the do not fill mark. I checked it correctly, level surface...shifted through gears and had it running. What would be the easiest way to drain some fluid out without dropping the pan? Do the 4r55e's have an auxillary cooler? Keep in mind that I am a noob to transmissions. Thanks
