tylerwiseman1992
- August 1, 2013
- Farmington, Iowa
- 1994 Ford Explorer
Hey guys,
So I have a slight dilemma, last weekend it was pretty hot here in Iowa and I was pulling out some hedge roots with the Ex. :exp: I had 5 to pull out, and everything was going smoothly at first. I pulled the first 3 out with a little jerk in 4-low and it was going good. So I was pulling on the 4th one and I was reving it up quite a bit since my explorer is a 5 speed and it was requiring some jerking on the chain to get it out. But right as It came up i noticed a grinding noise like gears that were stripping, I had originally thought it may have been my transfer case because i know it needs replaced. I moved it around a little after and it didn't do it again so i continued on my way to pull the last one, which came out with no problem. So right after I finished i noticed my heat gauge was pigged almost all the way up, almost to its max, if not there. So i drove it around the block to see if it would cool down, but no luck. :thumbdwn: So I stopped back at house and let it cool off, and noticed my coolant was boiling. So after it cooled down I popped my radiator and the coolant was a little low (probably all that boiled back into the reservoir since it wasn't that low) so i drove it home and realized that the only way i could keep it cool (now 75 degrees or so during the evening) was to turn my heat all the way up and suck some of the extra heat off the engine. I decided I probably shouldn't drive it to work this week and drove my escort. I went to start it this weekend and when i first started it i heard the grinding noise just briefly after the start then it was gone, i could rev it up and move it around and nothing. I then let it set awhile while i was working on my car and when i started it again the same thing happened. Grinding noise then nothing, ran fine after 5-10 seconds. So I'm curious is there any gears in my water pump that could be stripping under stress and causing my cooling system to not perform as intended? Or am i missing something?
