Gaetan
- November 19, 2009
- Los Angeles, CA
I have a 1997 Mercury mountaineer all wheel drive V8, and today it over heated , without any warning or aparent loss of coolant, I noticed it when driving on an incline in a 101 degree weather, all of the sudden my ac was blowing warmer and warmer air then I noticed my temp guage was going up drastically, I immediately pulled over to prevent it from going into the red. I opened the hood got a towel and undid the radiator ( bad idea) the towel flew up along with the radiator cap steam and water spewed absolutely everywhere, I let it sit for a while until a freeway service patrol pulled up, refilled my radiator, its then I noticed that my reserve tank was full to the brim which is also unusual. I let the car sit for a few minutes to allow the new water to equalize in temp a little. started back up and made it about 2 miles until bam same problem pulled over again, ( on a busy overpass that was fun) freeway service patrol came by again, called a tow truck ( this took about 1 hour so the car cooled) tow truck tried to tow the car but couldnt because of the all wheel drive, which dawned on the tow truck driver when he heard the rear tires screeching while trying to tow. At this point I had to drive the car to next exit, he filled up my radiator again which was still missing a bit, I took off and the car worked fine went up to normal temp and stayed there. To be safe got off the freeway as soon as possible and called AAA. Got home safe.
About a year ago I got a new radiator, which began leaking, I took it back for waranty, and the mechanic at first welded it, it leaked again I took it back and the leak mysteriosly dissapeared I think he put stop leak in it (300 and I get a radiator with stop leak ) 3 months ago I replaced all of the hoses. I dont know what is wrong with my car, I would like to figure it out and fix it myself since I do not trust my mechanic any more, or if someone could recomend me a good honest mechanic around Los angeles, CA that would be great. Any advice would be greatly appreciated Thank you- Gaetan
