JMSports
- November 7, 2009
- Long Island
- '96 Sport
I have a 96 Sport with a 4.0 and 241,000 miles. I had a CEL P0401 for EGR insufficient flow, as well as P0420 Cat Converter Efficiency below threshold.
I replaced the valve itself (which now I realize I didnt need to do), and the code came back. I blew out the lines going to the DPFE and a bunch of small **** came out. Code still came back. I replaced the original DPFE with an updated plastic one. Code still came back. I took the valve off to check for vacuum at the intake port of the system and it damn near sucked my finger in so theres plenty of vacuum. Code still came back. All that left to check is the Solenoid. With the engine at idle, that little green vacuum tube that goes to the top of the EGR is pulling vacuum. Im not sure if this vehicle has a pulse width modulation system or not, but Idk if I should just replace the Solenoid. everything else is replaced.
Any Ideas? (btw im not getting the 420 code for the cats, just the EGR code keeps coming back)
