Pa 853 steering shaft extension bolt!!! Help! !! | Ford Explorer Forums
35's on mine
S. Fla
1997 explorer
The extension bolt does not slide on the upper shaft all the way. On my explorer the upper steering shaft has a metal nub keeping the extension from go all the way on. Should I grind this nub down??????
Does it not flip around and fit? Grinding is fun :)
no ,not at all,, five min.. from grinding -- guess i have the go ahead
The difference is about 1/8" correct?
Seems like i had to grind off bit when I installed a 97 shaft to my 98 mounty a long time ago-I see no problem with shortening the shaft.
I remember on my old 97, we had to grind a little nub on the steering shaft. Use a die grinder and grind it down to fit.
