Painting brake calipers | Ford Explorer Forums
aldive
Elite In Memoriam
1999 XLT
A project that has been simmering on the back burner for quite some time finally got my attention – painting the brake calipers.
After considerable research and questioning people with painted calipers, I decided to use Dupli Color Brake Caliper Paint ( http://www.duplicolor.com/products/caliper.html . This ceramic-based, brush-on paint is designed to withstand temperatures up to 500 degrees (intermittent).
I purchased my kit at Advanced Auto Parts for $17.06 including tax. I chose the red color ( personal preference ).
The kit includes everything you need to paint the brake calipers: Caliper Cleaner, Caliper Paint, stir stick, paint brush, masking tape and complete instruction book. The kit includes enough to paint four calipers.
I chose to do the front two calipers and then do the rears the following day.
The first step is to chock the rear wheels, jack up the truck and securely place jack stands. My air impact wrench made the wheel removal a snap.
I used an air blow gun to remove any brake dust and loose crud from the rotors. This was followed with a through blasting with Brake Parts Cleaner ( I placed a catch pan under the rotor to catch any dripping solvent ). Now the Caliper Cleaner ( supplied with the kit ) is sprayed all over the area to be painted; a small wire brush and an old toothbrush is used to thoroughly clean the caliper. The next step is the masking off the areas around the caliper that is not to be painted. The brake bleeder is masked as well.
The paint was thoroughly mixed and the caliper was then painted with the included brush, A second coat was applied after 30 minutes ( and must be applied within 1 hour or after 5 days [ per instructions ] ). This pain dries very fast.
I let the calipers dry for 6 hours and then reinstalled the wheels. I did not drive the truck for 12 hours.
Even though I have the stock tear drop wheels, the red paint on the calipers shows somewhat. The calipers would look much better through a more open wheel.
Would think removeing the caliper would me a better way, also the high temp dupli-color with ceramic in the rattle can is good to 1200 Degs.
Whatever works I guess
Nice write up Al. Whenever I put my Powerslot rotors up front, I'm gonna paint the calipers and probably use the same kit you did.
Looks good, Al. Got any pics of it with the wheels on?
Thanks and no wheel on pivd yet; my Sony camera battery died. Will post when I get some.
The surface of a caliper will never reach beyond 500 degrees, won't even come close. This kit works fine, I actually prefer the brush on kit because its a lot easier than masking the caliper off and spraying or removing the entire caliper.
Here are a few ....
I used the duplicolor with cermic on mine. Just semi-gloss black for me though. Reds too flashy. But yours look good.
I went with black as well, Folia-Tec. Looks great man, nice and clean.
looks like a neat project, good to hear they still look new(so the paint lasts). I think I will be doing this project soon.
dammit, now I have another thing to put on my to-do list :)
I always figured painting the calipers wouldn't be worth the trouble, but this seems too easy, so I have no reason not to do it.
And 7 months and still looks good huh?
That may be the biggest selling point there.
thats what sold me
red = HP
silver would have given you better MPG. :D
I went with red on my Zuk for that reason.. it needs the help. Used the duplicolor engine stuff on mine though as it was less than $5 and is a spray. My calipers were not on so it was easier probably. Looks great with the flat olive drab rattle can paint job! :D
Looking good Al :thumbsup: It is a nice project to help keep your truck looking good... I can't stand rust (it just makes my skin crawl)... Prep work is the key to a long lasting quality job. I cleaned my calipers with brake cleaner, and then sandBlasted them to remove all rust (then washed them in dish soap).. The side benefit of sandblasting is that it etches the surface and gives the paint (or coating) your using something to grab hold off (sort of like velcro)..
So are you going to work on any other restoration?
Well its been 2 years and I had to pull the wheels and do a brake job and a wheel bearing job today.
Took a good look at the painted calipers and thy were no longer bright red; they had morphed into a dull redish color.
I reckon the heat had taken its toll.
Will I repaint? Doubtfull.
I used the same DupliColor kit on my Ranger. These pictures are from a couple of years ago. Like yours, the color has gone a little flat since then.
Nice. Never seen this thread. Definitely gonna do this.
