ioamnesia
- June 12, 2007
- Everett, WA
- '98 SPORT
Howdy. I'm in the 2nd cirle here so please help me out. After changing the oil on my 98 explorer I removed the harness from the PCM to get the shield off for voltage testing (dreaded p0171 and p0174) and plugged it back in. In the process, pin 26 was bent over. The car was running rough on my test drive after working on the car and broke down about a block away. Crank, no start. I pulled the PCM out and noted the bent pin which, as far as I can tell from the scematics, goes to the ignition coil. I carefully unbent the pin and replugged in everything, making sure not to have a repeat performance. No Start!
I checked the fuel rail and have zero pressure. Relay is good. I bridged the relay to start the fuel pump and got pressure to the engine. I then tried to have someone start the car as I shorted the relay ports and still no joy.
I don't know... did I fry the PCM? I probed the wire and the lead to the relay and the relay is not getting voltage from the PCM when the key is turned on. Is it possible somehow the whole chip in key system was wonked out somehow and the pcm is not recognizing my key?
