540milotalon
- August 25, 2019
- 1998 Eddie Bauer
I had a wrecked '99 Mountaineer, 5.0 2 wheel drive and access to a 1996 Ranger 3.0 bad engine, also 2 wheel and both A/T, A/C
I did a swap, problem is the wiring is not 100% compatible.
I need the pin location for a '99 PCM and I have the Ranger.
The VSS is rear driven on the Mounty and trans driven on the Ranger.
Supposedly, all I have to do is relocate a couple pins on the connector for the VSS and move a couple wires on the tach and I Will have a speedo and tach.
I also have to get around the PATS or have it reprogrammed.
Any help, any link to the correct pin configuration will be greatly appreciated.
