PCM Update | Ford Explorer - Ford Ranger Forums - Serious Explorations
PCM Update
JohnnyO
Moderator Emeritus
Pittsburgh, PA
2020 Ranger
My '08 finally started the accessory drive squeak, there is a TSB, so I took it to the dealer this morning. Ordered the parts for that, also they told me there was an update to the PCM that they put in. Just a heads up.
Also they reflashed the transmission. Been taking its own sweet time going into reverse.
Something about a KAM module too that I didn't understand. :confused:
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Fordham
Macon Georgia
2007 Explorer
I just took mine in for the "slow to go into reverse" and got a PCM update. I really ain't ready for them to crack the pan on mine. I only got 4500 miles. I will see when it's cold if it fixed mine. Mine does not do this when it is hot. Does yours do it all of the time? Mine also doesn't have the accessory drive squeak yet.
Thanks
Clay
JohnnyO
Moderator Emeritus
Pittsburgh, PA
2020 Ranger
Mine has 23,000 miles. Going from Park to Reverse is okay, it's when you go from Drive to Reverse that it takes its sweet old time. Does it all the time, hot or cold.
The squeak was worse over the winter. When the weather warmed up it went away until yesterday when it suddenly got really loud.
Xjman1
Oxnard, CA
'07 SportTrac Limited 4x4
Is this an issue with the V6, V8 or both?
JohnnyO
Moderator Emeritus
Pittsburgh, PA
2020 Ranger
Just the V6 as far as I know.
Infinity08
Charlestown, IN
'08 Sport Trac LTD
Nope. I had it fixed on my v8, too. It sounded like a train whistle at temps below 40F.
JohnnyO
Moderator Emeritus
Pittsburgh, PA
2020 Ranger
Got it done yesterday, apparently the fix is a new belt and alternator bracket.
0uTkAsT
Tempe, AZ
2008 Sport Trac XLT
I have an '08 V6. Since there is no TSB out, if I just take my truck in to the dealer and tell them I want the latest ECU & tranny flash, will they know what I'm talking about?
Gus Gorilla
The Cradle of Naval Aviation
2001 Sport Trac 4X4
They may or may not depending on the dealer. Some dealers are really good about checking Oasis for updates and they really know their stuff. Some are still in the dark ages and only learn about things like this when customers like you bring in a vehicle and tell them about a reflash. More than likely if it is a big dealership, the technicians will know.
UIN2IT
Tampa, FL
2008 Adrenalin Sport-trac
Anyone know what the TSB Number is for the Accessories squeel? I've had this happening too but thought it was casue of my Pulley's!?
thanks!?
Infinity08
Charlestown, IN
'08 Sport Trac LTD
thanks!?
08 04 02, which replaces part number 6L3Z-6C348-A
If you have it, you'll know it. VERY annoying, and almost embarrassing. Well, you don't get cold enough for it to get REAL bad.
0uTkAsT
Tempe, AZ
2008 Sport Trac XLT
Awesome! Thank you!
