dude that is not your pcv valve. the pcv valve on the 01 sport does not connect to your intake. you can take that tube off if you want and put a breather filter on it. The pain in the ass pcv is on the back on the engine on the drivers side. The pcv valve with the tubing wrapped around it is what you need. If you buy that part and look on the back of the engine you will see it. I haven't replaced mine because all the threads I read said it was a PITA. Good luck.
-Rich
