neon_boy82
- June 4, 2010
- Ontario
- 2004 Sport trac
Hi everyone. I need some help with the rear brakes on my truck, specifically the driver's side. I replaced the pads and rotors on both back brakes last summer. A few months later I noticed a grinding noise coming from the driver's side so I pulled the wheel off and took a look. The pads were completely wore down, metal on metal. All the brake components were coated with brake dust. It's like they were seized on. I took it all apart, the piston on the caliper seemed to work fine and the slide pins worked well too. I bought new pads an put them on. A few days later after about a 30 minute drive the brakes started amking noise again. They were sqealing in a rotational patern and it was more noticeable under low speed turns ( like from a stop light). Anyway, I just checked them out again today. The pads aren't wore down as bad this time but the noise is getting more frequent. Again, the caliper seems to be fine. I was told it might be a problem with the rubber lines not releasing pressure but I can't tell if they are bad or not. If anyone has any experience with this or and ideas what might be causing this problem I would appreciate your feed back. Thanks.
p.s. Sorry for the long post
