Power steering fluid | Ford Explorer Forums
emolina
Los Angeles, CA
'97 XLT SOHC
Going to use the turkey baster to change out the power steering fluid. Since Mercon is no longer made, is it safe to use Mercon V or is a Dex/Mercon the better choice?
Mercon V ATF. I've used the turkey baster method (a full flush is better) but if you do it a couple of times over a couple of days, the baster method seems to works well enough.
Turkey baster it is. Thanks for the info.
