all4ford
- October 6, 2006
- 95 Explorer
Hello all..
I just replaced my rack and pinion after 2 shops both condemned it as bad. After installing a new rack, I have added less than a quart of power steering fluid and my resevoir is full. I started the truck and had a friend keep oil in the resevoir at all times. I went back and forth about 10 times with the wheel (Avoiding hitting the stops) and I still have no power steering.
My thoughts went immediately to a bad pump. I did notice that if I cranked until I hit the stop, the pump whined or at least sounded as if it has pressure. Could I still have air in the system, it should take more oil than what it has??
Thanks
Thanks
